drmichi wrote:
I would like to control the floor stand from a NodeMCU V3 micro-controller, which is attached to the USB port of the TV and a separate power supply.
- When TV is starting up, the NodeMCU detects USB power and moves the floor stand in the defined position
- When TV is turned off, the NodeMCU detects that USB power is lost and moves to the zero position
- Optionally, through an IR receiver I could also be possible to manually control the floor stand through a remote (e.g. Beo4)
Great simplistic approach! Perhaps this can a bit of help. I believe the control signals are 5V, but they might work with the 3V3 Node I/O. Note they are active low. The feedback can be read by the ADC. I would guess it's centered around 5V but i really don't know! Check the signal before attaching it to the node, you might need to scale and perhaps offset it! This schematic is not that clear but W50 is the cable hanging loose in your picture. I have always wondered exactly how the two active low signals can do FOUR different thing, left, right, up, down. Perhaps you will find out?
Bottom line the BV7-40/55 stand is significantly more complicated than the BV7-32.
EDIT: If you scrap the TV anyway make sure to scavenge the IR receiver board it could come in real handy for your project!
