If you use an audio aux inout box on the beomaster 5 then you will have a delay. It’s in the documentation. Picture and sound will be out of sync, so this isn’t a solution
Connecting LG TV to Beomster via 1611 converter
Hi there,
Thanks for all suggestions and comments.
I still have not solved this issue. Is it possible to inject audio direct into the masterlink socket on the beomaster 5, and if so can anyone tell me the relevant pin connections. This would then confirm the beomaste 5 was OK, although as I said it works OK for all other sound selections.
Thanks and regards
Terry
