Does anyone have a suggestion on how to connect my 2400 to a laptop PC? I looked for adapter cables to no avail. Perhaps someone knows of where I might find such an adapter.
Thank you,
Thomas Preiss
Thank you,
Thomas Preiss
Hi Thomas, I think that Steve at Sounds Heavenly, a forum sponsor, sells exactly what you need
http://soundsheavenly.com/bang-olufsen/67--trs-5pd-.html
Having said that, I did this years ago and used a combination of 3 things that were commonly available around me, where DIN connections are not common. So I have a DIN ->RCA cable, two barrel connectors (female RCA both ends) and then a standard PC to RCA cable.This is connected to the Tape input of the beomaster.
Thank you Ryan from Toronto. Long may Neil run.
Thomas
Thank you for the tip. I appreciate the answers to my question.
Thomas
