Hi Forum,
I want to add a second Beolab 2 to create a 7.2 surround setup, my TV is BV7-55 (mk1)
The first Beolab 2 sub is connected to the Sub socket on the TV. however I cant find a second sub socket. If I connect the second beolab2 to the other powerlink sockets, the TV thinks the beolab2 is a normal speaker, and that does not give the correct sub sound.
My question is, where do I connect the second Beolab2, so that it gets the correct sound?
In the TV menu, Photo below, I can see that a second subwoofer can be added, however at the moment I cannot control it (the field is greyed out), on the second photo, you can see the menu where I can choose the position of the 2 subwoofers, so the TV should be able to control 2 subs (The menu text is in Danish)
My 7.2 line up:
BV 7-55 (Mk1), Front: Penta Mk3, Side: Beolab 6000, Rear: Beolab 4000, Subs: 2x Beolab 2
