Hi there,
I have a beomaster 1200 and I need to clean the potentiometers. I have noticed that they are pretty hard to remove from the actual machine in terms of removing the circuit board.
Is it best to desolder them form the circuit board, clean and then solder back into place, or can they be cleaned in place.
The only concern I have is that if I clean them in place then all the dirt and dust will just get spread around the rest of the machine? I am also a little unsure of what cleaning fluid to use?
Any advice of help would be fantastic.
Matt
