Change order of List menu for TV
Hello there
When I had the IR only version of the Beoremote one with my avant 55 I could change the sort order of the functions in the list for TV menu.
Since moving to the BT version the TV and MUSIC options are according to the TV setup,
BUT the list menu cannot be resorted.
is there a way to do this?
I would like my Homecontrol function to be at the top of the list.
Cheers
Sean
Even though it's a delayed response.
AFAIK, there is no way.
Yes, you used to be able to do this, but now with BT, it's two way and it takes the sources from the device.
You can change the order of the devices, eg; if you want BV14 to appear at the top or BeoPlay A6, but control will always be under these.
Sean, did you ever get this sorted?
Regards
Michael.
I have a related question. In my list menu (TV) I have two time the same item. But in the app list of my (LG) TV only one time this ithem. Also I have under de list the item HDMI A, but have nothing connected to the HDMI A port. (the Stage is connected to a LG TV).
