Hi I have just bought a very nice Beogram Cdx, it plays fine only issue is the door, it doesn't lift or go down, also the small CD platter doesn't lift when you manually open it. The eject button releases the mechanism but that's it. Could this be an easy fix please? Thanks Phil.
CDX Door issue
If you can hear the motor running, then the belt has most likely snapped or the gear has lost its teeth.
If not, check that it gets power. If no power check the driver circuit and the switches associated with the eject function.
The lower "paddle"-part of the disc lifter plate has probably broken off. You may be able to repair it - else replace it.
