Hi all,
So I've had a CD 5500 I picked up which wouldn't read cd's. Only after investigating the forum and the "easy fix" of the 33/47 uF blue Philips/BC/Vishay cap did I part with my money...
So, replaced it. No joy.
Replaced the 4 other electrolytics on the servo board, still no joy.
So here I am, asking your expertise to identify my problem!
Basically, after all the work done the following happens:
1. Press open. Tray opening is slow to respond (the belt tensions then releases with a full forward jerk (ie, replace belt)).
2. machine turns off once open
OK, so place CD manually in the tray & close:
1. Press play. "Track" lights up.
2. Hear the laser assembly smack forward against the white CD2 assembly plastic, motor attempts to spin cd (feeble), then CDP turns off.
Apart from replacing the caps I have made no other adjustments (apart from giving the three PSU regulators some soldier attention)...
Any knowledgeable people out there to give me some new pointers? If not, I'm back on the market for a working CD5500...
Thanks, Sam
