Can't control DVD1 with Beo4 Remote (MX7000)
Hello!
I have aquired a B&O DVD1 player to use with my Beovision MX7000
I'm using a Beo4 remote which has a DVD button, but nothing happens when I'm pressing it.
By selecting "V.Aux" from the list on the Beo4 remote, I managed to get picture from the DVD1 player, but I still can't control it with the remote?
Could someone please help me determine what's causing this problem? And eventually how it can be fixed?
All help is greatly appreciated. 🙂
Thanks!
You need to go into the menu of the TV and 'name' the input as 'DVD'.
To do so, press TV, then MENU.  Go to SETUP, then SOCKETS then scroll right to AV2.  Use UP and DOWN arrows to select DVD and then press GO.
It should now work!
