Could you perhaps post a picture (probably two) of the Source Menu of the tv?
It would appear the (SOURCE) in the parenthesis is the 'button' that will activate it.If so then it makes sense that AV IN does not activate. However I don't know how to configure these.
What are your options under Från Standby?
It is now set to Inga (which I suppose means Nothing).
Yeah, it's set to none. The only options are None and TV. When set to TV, the TV button on the remote starts the Beovision on the AV input, so that works as expected. But it's not really how I'd like it.
What would you expect to happen, then?
Isn’t the TV command/button ok?
That option is to turn on the source from standby, not switch to it when the TV is already on. I would prefer to be able to access it from the source list in the remote
