Can't access AV IN on Beovision 11 with BeoRemote One
There doesn't seem to be a command in the BeoRemote One to access the AV input on the Beovision 11 mk2. I've tried adding all the sources on the remote but none of them will activate the input.
There is one labeled AV IN on the remote but it activates the radio instead. Is this a bug? I will have to use the menus to access this source instead of the TV or MUSIC source buttons on the remote. Very frustrating.
On the Beoplay V1 you have to assign the AV in port to a source in the setup menu of the TV the same way you asign HDMI ports. Guess its the same on the BV11.
This used to work when using the Beo4 remote, but there is no such option when the TV is configured to use a BeoRemote One.
If you have started the AV IN source from the Source Menu, can you then assign a MyButton to it?
If yes, that might be a workaround.
I havent tried a beoremote one, but shouldent the source be the same as on a BEO4; V.MEM for example if thats the dource assigned to the AV In port?
What source button did you use on the BEO4?
On my BeoRemote One BT I’m able to add AV IN under TV sources for my BV 11 - see screen shot below:
I do this on the remote by selecting:
LIST / Settings / TV-sources / Show / AV IN
Edit - sorry I didn’t see in your first post that you found it yourself😕
Best regards
Dyssegaard
Yes, that's what I need to do I think.
I could use any button, because the source menu allowed for setting any of the buttons. This is not the case if the TV is set to use the BeoRemote One. Then you cannot assign buttons—the remote is supposed to have all the commands listed.
Yes! It's there but it starts RADIO on my TV for some stupid reason! I
I have just tried to use it, and on my BV11 it start up the AV source as expected.
Best regards
Dyssegaard
Makes sense. I’ve reset my remote and the issue persists. Somethings going on with the TV
