Dear all,
until 3 weeks all worked perfect: BV10 (internal DVB-C) worked like a charm. So did HDR1 (recording with analog cable input), activated via VMEM on Beo4. Quality does not really matter to us for the old stuff we record...
Unfortunately the cable company stopped analogue cable input...HDR1 has no signal anymore.
I wanted to try recording at least with the internal DVB-C in the BV10 (locking the TV due to only single tuner built in). HDR1 did record, even timer worked..however HDR1 could not be turned off - only by pulling mains.
First question(s):
Is the HDR1 broken? Is my "Fully" scart cable faulty? Is it a bug? could be according to a Raeuber Thread/discussion some years ago...
Second questions:
How could I connect a modern (USB)-Recording Receiver like e.g. technisat?
Challenge regarding Beo4 buttons:
TV = BV10 TV with internal DVB-C
DTV = Apple TV
VMEM = should stay the comand for the recording if possible (maybe hooking up the modern DVB-C recorder via SCART ?)
Would I need to stop using the internal DVB-C and use a Twin receiver that could be activated with "TV" button so that Apple TV stays at DTV?
Regards
Thomas (Munich)
