I have a BM5 and BS5 that have been sitting on a shelf for a while. I decided to dust them off and connect them to a vintage non-B&O amplifier.
I connected the Line Out from the BM5 to the Line In on a Phase Linear 4000 preamp. It sound awesome, but I can't control the volume from the BS5. When I spin the volume control it shows a blue arc indicating full volume. I am using N.MUSIC as my source and streaming from a Twonky server.
I used to have the BM connected to another amp and it worked back then, but I also had it connected to a ML system and it was the Audio Master if that makes any difference. It is still the Audio Master, Option 0.
What do I have to do to be able to use the volume control on the BS5?
Thanks.
