Hi all, I have a BS5 system that after 1.5 years accessing the Internet through my home network has suddenly stopped working and in the settings under network info it tells me that there is NO network connection!
The only thing that has happened is that my power at home has been switched off and on due to some electrical work being undertaken. The BS5 locked up and just sat with the Red LED flashing. I rebooted it and everything started OK but since then No Network Connection.
I have checked the RJ45 connection with another computer and have moved my access Unit into the same socket and all is OK. My network switch is seeing the BS5 as the LED light is on.
This seems to be a software problem. Is there a way to check this please?
Has anyone else had this problem?
Cheers Trevor.
