boelab 8000 speakers with faulty standby transformer
Hi
I'm currently trying to fix my beolab 8000 speakers, and found that the standby transformer is burned out.
Does anyone know the specifications of this transformer, or if its still possible to get a replacement part. so i can get a new one. ?
Regards
Where are you located?
I have a replacement one. With the proper voltages. Not the wrong version which you can find on ebay.
PM if you're interested.
Hi Tried to write to your mail. but no reply
Hi I am repairing a Beolab 8000 , with a faulty st,by transformer (NT 8049, 8013473) .
Do you have a transformer please .
Kind Regards
Colin
What mk are they?
Bang & Olufsen Addict
RL60.2, Penta MKIII, 2 Pair BeoLab 2500, S45.2
BeoMaster 4500, 5500
BeoSound 2000, A1 Gen 2. 2x BeoSystem 2500
Beoplay HX, H9i
Hi. I’m also searching it for my mk1 bl8000. Has anyone found replacement yet?
I can supply replacement transformers for 230V market.
PM if interested. Will check spam box as some emails ended there.
Email sent. Please check. Thanks
