I have a Beomaster 7000 that would not keep correct time after the power was disconnected. I removed the CPU module and discovered that the Lithium battery (CR2450) was leaking. After having replaced the battery with one of the same type the Beomaster now will not respond to any commands from the remote.
The Timer Off light is on and if the Mute/Power button on the right is pressed, the display indicates 7. Successive presses changes the number from 7 to11 to 22 and back to 7 again.
Not sure if these are error codes or not. Any ideas on this fault?
