I have a BM6000 that I put down a couple of years ago because I suspected the CPU was broken but after browsing the old workshop forum today I decided to have another look.
The machine has been fully recapped and when power is applied one of the volume arrows lights up and there is a single zero in the display.
The 6.5 volts looks good and the processor reset looks like it is working but what I don't see is the 50Hz into CPU pin 16 from the PSU. Should board 16 (the PSU) really output a 5v square wave as indicated in the circuit diagram? I have changed 16TR4 twice but it makes no difference. There is a reasonable square wave on the base and it is biased at 0.4v. Does anybody remember if they have seen a nice 5v 50hz square wave on P42-1 and is the square wave still present if the plug is removed? I am assuming the CPU is acting as the load on the collector of 16TR4.
Richard
