Hi All... this is my first posting, so apologies if I don't get it right...
I have a BM5500 that would not bring on the STANDBY LED at power on... It turned out that the lithium 3v battery had expired, exuding fumes that had corroded the EPROM legs/socket...
I have replaced the battery and cleaned up the EPROM/socket, and the unit powers up normally...
However, if I set the CLOCK with the MCP5500, it starts running, and keeps time whilst the amp is powered, even in STANDBY... But if the mains power is removed, it forgets the time (and other parameters such as VOLUME, BASS etc)...
It is odd, as the real time clock chip is clearly running... the symptoms would seem to indicate that the battery is again dead (possibly answering my own question here)...
Has anyone experienced a similar problem??
Tony
