Thank you for your hints.
Maybe a dumb question, but what happens when I clone a 500GB HDD to a 1TB SSD? Will I lose the remaining 500GB because of an exact 1:1 cloning?
BM5 HDD to SSD the easy way
Typically with drive clones, when you use a larger destination disk the cloning software will just create a partition on the drive that's the exact same size as the old one. I can't remember if Windows XP (which it looks like the BM5 runs on) supports re-sizing partitions (and even then, I'm not sure if you can re-size FAT32 partitions), but if it does you can try using Windows' Disk Management (if you can get to it) and then re-size the partition from there. Essentially, the storage itself isn't gone forever - you just won't be able to access it unless you find a way to create a partition that takes full use of the disk's capacity.
Make sure you don't wipe the old disk in case re-sizing doesn't work and you need to start from scratch again - don't want to lose your music etc!
The HDD on BM5 is using NTFS.
The service letter describes in short what i wrote above. So as i wrote take the original B&O HDD and clone it to a SSD as described above.
Hi all
Iam glad it works and it is a great improvement!
I run the BM5 as hommedia server trough NL/ML converter on the BV11. Fast and easy! What I am missing is the video information of the album covers. More problems ahead.
regards Ruedi
If going from 500 GB to 1 TB one has to use the special software tools and follow the procedure decribed in the service manual
I am considering doing this as I just got my main board replaced for a 2nd time and am still running my original HDD.
Is the service manual available on this site with upgraded membership? If not, where can it be found?
Thanks,
Stan
Hi
A question regarding this Post:
Has anyone got a link to this Servicemanual and a specification of the software tool to be used? I plan to clone my 500GB HD into a 1TB SSD
Simon
Grüzi Ruedi.
Interesting story. I have a question, big request. I have visited many services, supports, but still no result. "Twonky" not responsible, "Beo" nothing to learn, and also the "technician" is not available. The following problem: I have BS5/BM5 and on the PC I can control everything. I play music videos (mp4) via the PC. I can select ONLY AUDIO on the "clients" notebook/smartphone NO M-VIDEOS. (M.Video does not appear) Probably "Release..." in "Twonky", this page ...... : 9000 does not respond. How/where can I reinstall Twonky? Is there a manual? Is there a "reset?" (do not speak much computer) Thanks for help. Salli
what can you control on your PC? the BS5? Twonky?I have BS5/BM5 and on the PC I can control everything
You mean Twonky doesn't see MP4's?I can select ONLY AUDIO on the "clients" notebook/smartphone NO M-VIDEOS.
did you install Twonky on your PC? or is it running on your BS5? if it running on your PC try also " 127.0.0.1:9000 ". if running on the BS5 then you must be in Windows XP Embedded (Service Menu) of your BS5. You can install Twonky on a Mac/PC/NAS/BS5 (= a PC)/Linux and yes you can reinstall it."Twonky", this page ...... : 9000 does not respond.
advice: first install it on your PC to learn how Twonky works.
Thanks for answer. Exectly, so it ease. I control from PC (Beo/Twonky only MUSIC) but on "Z:" i can handle Video and Audio. Correct, Twonky does not see "mp4" but i think there is no folder "Videos" anyway. Twonky is (as far as i know installed on BM5 by technicen) Ok, i understand, I will "first install it on PC to learn how it works" ;-) (I tried to install on BM 5, but does not work) Tanks Salli
