BM5 HDD to SSD the easy way
Thank you for your hints.
Maybe a dumb question, but what happens when I clone a 500GB HDD to a 1TB SSD? Will I lose the remaining 500GB because of an exact 1:1 cloning?
Typically with drive clones, when you use a larger destination disk the cloning software will just create a partition on the drive that's the exact same size as the old one. I can't remember if Windows XP (which it looks like the BM5 runs on) supports re-sizing partitions (and even then, I'm not sure if you can re-size FAT32 partitions), but if it does you can try using Windows' Disk Management (if you can get to it) and then re-size the partition from there. Essentially, the storage itself isn't gone forever - you just won't be able to access it unless you find a way to create a partition that takes full use of the disk's capacity.
Make sure you don't wipe the old disk in case re-sizing doesn't work and you need to start from scratch again - don't want to lose your music etc!
The HDD on BM5 is using NTFS.
The service letter describes in short what i wrote above. So as i wrote take the original B&O HDD and clone it to a SSD as described above.
Hi all
Iam glad it works and it is a great improvement!
I run the BM5 as hommedia server trough NL/ML converter on the BV11. Fast and easy! What I am missing is the video information of the album covers. More problems ahead.
regards Ruedi
Fritz wrote:
If going from 500 GB to 1 TB one has to use the special software tools and follow the procedure decribed in the service manual
I am considering doing this as I just got my main board replaced for a 2nd time and am still running my original HDD.
Is the service manual available on this site with upgraded membership?  If not, where can it be found?
Thanks,
Stan
Hi
A question regarding this Post:
Has anyone got a link to this Servicemanual and a specification of the software tool to be used? I plan to clone my 500GB HD into a 1TB SSD
Simon
Grüzi Ruedi.
Interesting story. I have a question, big request. I have visited many services, supports, but still no result. "Twonky" not responsible, "Beo" nothing to learn, and also the "technician" is not available. The following problem: I have BS5/BM5 and on the PC I can control everything. I play music videos (mp4) via the PC. I can select ONLY AUDIO on the "clients" notebook/smartphone NO M-VIDEOS. (M.Video does not appear) Probably "Release..." in "Twonky", this page ...... : 9000 does not respond. How/where can I reinstall Twonky? Is there a manual? Is there a "reset?" (do not speak much computer)   Thanks for help.                                 Salli
what can you control on your PC? the BS5? Twonky?
You mean Twonky doesn't see MP4's?
did you install Twonky on your PC? or is it running on your BS5? if it running on your PC try also  " 127.0.0.1:9000 ". if running on the  BS5 then you must be in Windows XP Embedded  (Service Menu) of your BS5. You can install Twonky on a Mac/PC/NAS/BS5 (= a PC)/Linux and yes you can reinstall it.
advice: first install it on your PC to learn how Twonky works.
Thanks for answer. Exectly, so it ease. I control from PC (Beo/Twonky only MUSIC) but on "Z:" i can handle Video and Audio. Correct, Twonky does not see "mp4" but i think there is no folder "Videos" anyway.  Twonky is (as far as i know installed on BM5 by technicen) Ok, i understand,  I will "first install it on PC to learn how it works" ;-)  (I tried to install on BM 5, but does not work)       Tanks Salli
