Hi guys
I just recently bought a 1TB BS5/BM5 and so far I have successfully upgraded it with SSD.
Since I am using 2TB WD Blue SSD, my initial intention was to expand available storage to 2TB, but I only managed to use it up to original 1TB. When I do re-partitioning of DATA partition with MiniTool Partition Wizard, BM5 boots up normally, but when I select Mode->System on main navigation screen, system crashes instantly. For the same reason I cannot enter the Service Menu to reboot it from Service Tool USB and do the Recovery... :-/
I would highly appreciate if someone who managed to use 2TB disc in BM5 can share the partitioning procedure steps.
Can I do it on another PC, or it's better do be done on BM5 itself?
Which disk partitioning tool to use?
Are there some partitioning parameters to be selected?
I am using BV7-40 as a monitor, have Service Tool USB and keyboard/mouse combo.I haven't transferred any music yet, so doing everything from scratch.
All suggestions are welcome
Thank you
Damir
