Not sure what is wrong - earlier today I removed the 2 old 250ohm trimpots from the amp circuit and replaced with new ones. Got back to it this evening to start on adjusting it, but got weird readings...right channel gave different values to left. Took me quite some time to figure it out, but I found the 2 1.6A fuses were done. Replaced with 1A as that's all I have on hand without going over spec, and they immediately blew.
I get +/-31ish volts both sides as per the specs, nothing looks wrong or solder bridges that I can see.
What could be wrong?
I'll have some follow up questions later on about how to do the adjustment as the instructions are a bit confusing and the diagrams don't seem to match the words, but for now...
