In case of buying new one, will the available 60V caps be a good alternative in stead of the present 50V ones ?
Aad
Aad
Will be ok.
I agree.
Though they are not reservoir capacitors but output series caps.
(Another filling up the gap in my knowledge, as I referred to in the first line of my first post of this thread)
Aad
I am back at where I was at the beginning of this thread and even worse:
I finally acquired the necessary parts that had to replace the ( possibly) faulty ones. To make a long story short: a headphone connected, I had the nerve to press the P1 (preset FM) key: For short a moment “l’histoire se répète”, as the French say: only one channel came to life, then I switched it off.
Then I connected one small speaker in order to find out if either the left channel or the right one was the problem, powered the 1700 on again and there was a short hum and everything went dead, no smoke. Quite frustrating! Unfortunately there are no fuses that can be blamed and I keep my fingers crossed when I am going to investigate the condition of the rare TE-darlingtons in the powerstage and subsequently check the other components.
Aad
Did you set the idle currents, before you connected speakers?
I hardly dare to confess: NO!!; In my eagerness to hear the result of my work I forgot this and I am now punished by facing the situation that the result is dramatically negative!!
But, wise men used to say: all comes with experience ( learning by doing): Impatience is never a good argument for anything.
Is all lost now? Is there any hope that the TE-darlington IC's survived the shockwave?
Anyway I have to start from scratch with equivalent type transistors; e.g. the BD33/34?
Aad
You set the idle current with no speakers attached.
Start with the trimmers in center position and power the Beomaster up on a variac while monitoring the idle currents.
So I am going now on a quest to find someone with a variac.
Meanwhile I would appreciate hearing an answer on my question about the use of the BD33 and BD34 as substitutes for the now faulty TE 1088 and TE1089.
Aad
