Hi all,
Some advice is needed if possible. I currently have NEST set up with my BLGW. I am simply trying to change the temperature and for 2way feedback. However, it worked once or twice to begin with but now the NEST doesn't respond when I ask the Beolink app to increase the temperature. Nor doe the temperature in the app update when I use the Nest manually.
I have reinstalled the NEST may times but with no success.
Has anyone else had the same issues - I wonder whether the protocol for the devices to communicate isn't solid enough.
Thanks,
Alex
