Best Foam Surrounds
Hi all,
Where is the best place to source foam surrounds in general?
Is there one place in particular that are very reputable when it comes to foam surrounds regardless of speaker type or brand ie.everything they supply is going to be good. Or there isn't one place for all, but different places depending on what speaker you have in particular?
Also, is what is a good repair kit for old foam removal, dust cone reglueing (black stuff?) and surround reglueing, or you guys that do this source all the products seperatky?
I guess it depends where you live!
I don't mind paying shipping costs.
I have had good success with the foam surrounds I have bought from link. I am in the USA and they are in the Netherlands. For the glue I like to use link. There are other good glues for foam surrounds but I like using their glue. I used it on my MC120.2, MS150 and MS150.2 Beovox restorations. I have also bought link. I have only used that once and it seemed to do the job so no complaints with that either. For my shims I use
Thanks so much. Will look into it.
[quote user="sonavor"]
Dillen wrote:
I haven't.
Who (or which places) do you recommend as an alternative?
John
The one with knowledge and the best fitting surrounds come from audiofriends.nl
Ask for Fred.
Thanks Beobuddy. That is good to know.
