It all depends on what you prefer, music style, physical size and design.
The Beovox MS150 are extremely nice speakers, nice to listen to and nice to look at and about the best
from B&Os range for your Beomaster 8000.
They'll be more than adequate for most purposes but they are power guzzlers and not particularly loud if you
ask an old mobile DJ like me.
I use 4 pcs of JAMO POWER 555 with my Beomaster 8000 in my livingroom.
With their extremely high sensitivity (0,8W / 96db / 1m), the Beomaster handles them with the greatest ease.
Large, heavy and industrial looking (especially if used without their black front panels) but lots and lots of power and
volume from the total of
4x 12 inch woofers with huge magnets and voicecoils in a Center Bass Reflex setup,
4x 2-inch midrange domes in cast horns and a whopping
20x 1-inch dometweeters with controlled dispersion.
With an amplifier that will output close to DC, the sub-deep frequencies are really sub-deep and with a power rating
of 350W (RMS - and they CAN take it!) per cabinet, the Beomaster is the weakest link - but you don't want to
play THAT loud at home.
They will play almost anything you throw at them with good quality and detail and if you are particularly fond of
pop and disco music, they should be seriously considered.
Not too expensive either but get some that still have the original woofers (even if in need of refoaming as they will be if not already done).
link
link
- And they are danish too.😂
