Beovox P45 / 50 bass units
Good work Theomaster, excellent job! Sound good?
Ben
Hi Ben,
thanks.
Of course there is no difference in sound, before and after re-glueing, they sound very good.
But now I can sleep well, no fear that the magnets will discharge their baskets soon. 🙂
Than I had one more issue with one of the wooden cover for the P's. It was broken but in the mean time I solved this too.
Speakers are connected to BM6000 and they are playing very well as front speakers together with C-30 as rear. Actually I am very pleased with the sound!
Back from vacation Ben?
Best Regards,
Igor
Great work, I bet they do sound really good actually.
I am back from holiday thanks Igor, lovely week exploring Stockholm!
Back to reality now, currently attempting to sort a few old Beolits!
Hope you are well,
Ben
Hi ;-)
Just took apart a driver from a 45-2, that had shifted. Thinking that if I could not fix it, at least I would gain a little knowledge ;-)
I noticed, that the little center metal piece (that you se after removing dust cap) had detatced as well as the magnet itself. Is this usual?
In regard to preventive gluing of other (still working) drivers, what are the chances, that the center part will detach on its own AFTER I have super glued the magnet?
Has anybody had that happen?
Thanks,
Jesper...
I have managed to repair a few of these in the past, never seen one with the core displaced as well as the magnet...though there is no reason it couldn't happen with a hard enough impact, and your correct....gluing the outer magnet in place wont prevent the core dislodging, however the outer magnet has to move to do this so gluing it in place makes it unlikely that the core can move on its own.
Craig
I sure hope, that the cores will remain in place.
I was just very surpriced to see/feel exactly how easy it was to take apart - the glue had was totally... well... unglued? I could literally just take it apart with my fingers.
And with Martin telling stories about how just moving the speaker, in some cases could shift the magnet, I just got extremely worried Erm..
Jesper...
