beovox ht 1500 speakers
Hi Has anyone any info on these speakers, i know there is info on here regarding them but i don't think any of it is correct. I would also like to know what the general opinion of them was at the time of manufacture. Thanks
Welcome to Beoworld !
What info are you looking for and why do you think that none of the info given in the product guide is correct ?
The Beovox 1500 is a rare speaker.
It has a pleasant sound for it's age, most likely because it has a considerable size for a 15W speaker.
Not a party-speaker but it will sound fine with a Beomaster 900 or similar.
Hi Martin I have a pair of these speakers which i found dumped at the local recycling center, i've been using them with an old valve amp wired through our digital tv and think they sound wonderful. The dimensions, weight and power handling are nothing like whats stated on here, so suspect the frequency response mentioned is also probably not correct and would like to know what this is. i also found a pair of B and O 2702's  and swapped the seas tweeters to the 1500's. John
Oh yes, the dimensions are definitely wrong, too small.
Maybe you can give us the correct dimensions ?
And maybe a brief description for us to include in the produt guide ?
That would be nice.  😁
OK, here are the correct specs for Beovox 1500 (Type 6209):
Size: 635 (width) x 280 (height) x 305 (depth), volume 38 Liters.
Three-way with crossover frequencies at 800Hz and 5KHz.
Woofer : Seas 28/17 TV-GW
Midrange : Peerless G 50 MRC
Tweeter : Peerless MT 25 HFC
Frequency range 45-18000Hz (DIN 45570).
Power rating 15W (25W max).
Impedance 4 Ohms.
Available in Teak and Palisander.
Has a midrange adjustment (rotating switch with 5 settings) at the back.
An owners review would still be nice.  👍
Done - are the pictures correct?
Thanks, Peter.
The photos are OK.
Maybe we should add that a 2-pin DIN socket is also provided for an external tweeter.
Done , and added the above picture!
Hi Thanks Martin and Peter for the info, regarding the Beovox 1500 speakers.
Thanks to sajpratty, we now have an excellent review of these speakers
