**Edit 3.31.14**
I took it apart. Kind of crazy 1. How darn heavy it is and 2. That it seems like B&O literally just took a Panasonic TV and attached the handsome aluminum frame around it. See the pictures below:
I'm able to turn it on via the power button, but the bunch of little buttons nearby, which I assume are the channel and volume and input buttons from Panasonic don't seem to do anything. Now I have to figure out what to do with the damn thing (which also weighs 100lbs or so).
Hi folks, first post here. I own a Beovision4, Beosystem1, which is the subject of this thread, but also proudly own a Beosystem2500 and speakers which have been really good to me.
So here's the problem. My system has been unplugged for 4 months while I moved from Chicago to San Francisco. I went to re-hookup the system and I'm running into the following issue:
System boots up via my Beo4 controller, TV turns on and displays the following image:
An attempt at a clearer picture:
For about 5 seconds. Thereafter, everything disappears and my controller becomes useless until I reboot the whole system. Repeat from step 1.
I called the SF B&O retailer because I suspected a PIN issue. They confirmed that it's likely a PIN issue and gave me a master PIN.
The problem is I don't even have the opportunity to enter the pin. In fact, I have no control over anything after the system boots up. I get the image shown above, it disappears and all I can do is turn everything off.
My research regarding entering the pin shows that I hit something that looks like an "I" twice, enter the code, then hit "menu" on my Beo4. I can't seem to find anything the resembles "I" on my controller. "1" doesn't work. When I hit just "menu", nothing occurs on the TV. What irks me is that no matter what I hit on the controller, the TV remains dark (on, but not displaying anything).
Any ideas? My B&O store has been helpful, but seem stumped at this point...
Much appreciated,
David
