BeoVision Avant 55 en UHD content
Heeft iemand ervaring met UHD (4k) content op de BeoVision Avant 55? - Ik had gehoopt er de Panasonic DMP-UB900 UHD blu-ray player op te kunnen aansluiten via hdmi 2.0 maar via BeoCare kreeg ik te horen dat de BeoVision geen HDR-signaal aankan.
Begin mij zo stilaan af te vragen wat het nut is van deze 4k TV indien er op geen enkele manier 4k content op bekeken kan worden.
Via de blu-ray speler had ik Netflix in 4k willen bekijken. - Zijn er andere 4k bronnen?
Apologies for the English reply...
You must use 'HDMI 1' socket on the Avant for UHD /4k sources with content protection.
The Avant does not support HDR (High Dynamic Range) but this is something different and does not prevent it displaying 4k content.
Hope this helps,
Martin.
Thank you for the reply. English is no problem.
The reason for my question was that I would like to buy a Panasonic UHD blu-ray player (DMP-UB900).
The manual says: "To view Ultra HD Blu-ray content in 4K/HDR format, connect to the HDMI terminal of a device that
supports HDCP2.2, 4K (50p/60p) 4:4:4, and HDR signals that meet Ultra HD Blu-ray standards
Beocare informed me that the BeoVision "unfortunately does not support HDR".
The Panasonic manual gives these details concerning his output signals:
4K(50p/60p) Output
This unit automatically chooses to output images in 4K*1 (50p/60p) when connected to a 4K (50p or 60p) compatible TV.
  • This item is available only when “Video Format” is set to “Automatic” and “4K”.
  • This item is not available when “HDMI(AUDIO) Output Mode” is set to “Video+Audio”.
  • To connect to a TV that supports 4K (50p/60p) 4:4:4/8bit or 4K (50p/60p) 4:2:2/12bit, select “4K(50p/60p) 4:4:4”.
    Images will not be output correctly with an HDMI cable that does not support 18 Gbps. (The supplied HDMI cable supports 18 Gbps.)
  • To connect to a TV that supports 4K (50p/60p) 4:2:0/8bit, select “4K(50p/60p) 4:2:0”.
Is any of this standards supported by the Beovision Avant 55? Anyone knows?
Kind regards,
Luc
Als jij Netflix in 4K kan ontvangen, dan zal dat zeker ook op de avant kunnen spelen.
De 4K resolutie staat los van het HDR gebeuren.Dus zullen er best andere bronnen zijn die 4K kunnen weergeven. Mijn TVIX 3DS2 kon dat jaren terug al.
Als ik het goed begrepen heb, is HDR een verbetering van het dynamisch bereik van het contrast/helderheid. Dat bereik is als het ware verfijnd met meerdere stapjes, waardoor details die eerder verloren gingen, nu wel zichtbaar worden. Als voorbeeld. Bij een te hoge instelling van het contrast worden donker grijze details afgerond naar zwart. Bijvoorbeeld een persoon die een zwart pak draagt wordt dat pak een grote zwarte vlek zonder details.
Dat HDR maakt het mogelijk om toch (bijvoorbeeld) bij al die donker grijze tinten van dat pak zichtbaar te maken.
Wat ik denk is dat er dus op meerdere punten in de schakel, bron-videoswitch-display (speler-AV mediacenter-scherm) er HDR omzetting mogelijk is.
Correct me if I'm wrong.
Dus dat zou net als met het upscalen van SD naar HD voor een paar jaar terug, gebeurde dat of in een DVD-speler met HD uitgang, of in de tv (zoals bij elke Beosystem 3 gebaseerde BV), of in een AV processor die ertussen zat. Het geupscalede videosignaal was bijvoorbeeld niet door alle schakels in de videoketen te sturen, omdat het niet ondersteund werd door de benodige aansluitingen.
Ik denk, en dat mogen anderen aanvullen of verbeteren, dat HDR een optie is in- of uitschakelbaar is. Ook als het in de bron aanwezig is.
Overigens ben ik benieuw of een 4K netflix film er beter uitziet dan een Full-HD beeld van een Blu-Rayspeler. Dat 4K wordt toch ook gecomprimeerd om over internet te kunnen verspreiden.Maar dat is een andere discussie.
Beobuddy's explaination looks perfect (at least those parts that google managed to translate into English).
Connect the player to HDMI 1 on the Avant, and select “4K(50p/60p) 4:2:0” and it will work fine. In fact you probably won't need to choose anything as it is likely that the UHD player will determine these settings automatically, but this is the correct option to choose if it doesn't.
Kind regards,
Martin.
Thank you for the reply!
Nu nog even wachten tot er een PUC lijst aangepast is. Dan waag ik mij er misschien aan zo een player aan te kopen.
Kind regards,
Luc
apologies for the english reply
i have already heard that samsung and panasonic have brought out HDR Blue ray players and they are already some movies you can buy to watch on them
unfortunately I am like you my avant os not a HDR TV and therby will not benefit from these players and until the MK11 avant comes out
i have seen 4k content throuh amazon and it does look very good but i think the movies watched on the hdr players will be better
you have to connect onto the HDMI1 port as that is the only one for 4k content
hope this helps
I disagree - the Avant absolutely will benefit from a UHD player over standard HD (more so with the larger screen sizes). The lack of HDR support means the next generation of Avant may be better still, but given the HDR standards didn't exist when the Avant went into production it is understandable that is isn't supported. Other 4k/UHD televisions prior to 2016 lack UHD support too.
In all likelyhood they will (even without HDR) as there aren't the levels of compression involved when compared to the Amazon 4k streaming service.
It;s not strictly true - HDMI 1 should be used for a UHD Blueray player / 4k streaming box, but HDMI ports 1 thru  5 all support 4k - it's just that only port 1 supports the HDMI/HDCP revisions required for UHD sources with content protection.
Martin.
