Beovision 9 speaker..
The centre speaker has just stopped working, was working fine and then nothing
When you connect the power terminal to the terminal on top off the metal cage, all the circuit boards that are housed it clicks then the speaker produces sound then clicks off....is this an expensive fix or do I try and get it repaired ( I no nothing about electronics)
Would anyone with knowledge in this be able to fix or is it b&o?
Did you get this problem fixed? Mine has developed the same fault.
