Beovision 9 Screen Removal How to- but problem not gone away
Small update... Login to view imageTo raise base inline with fret cloth Login to view image Login to view image Login to view image Login to view image Login to view image Login to view image4mm height difference on new base to speaker fret for flush fit of new screen
Ok.... frame work complete and painted....Matt black: Login to view imageDressed timber up the sides to take up the tolerance 1-2mm Login to view image Login to view image Login to view imageAmp to be fitted Login to view imageReady for new 4K HDR+.....blah blah blah....tech speak
Hi Brambl, did you instal the new screen already? I would like to see it 😉
Please post a pic of this as a finished project, work looks great what you have done so far
