Hi everybody,
I bought a broken BV6 22 and I want to try to repair it.
These are the symptoms:
When I plug in the power the standby led becomes greens for a few seconds and then goes out and a second later it becomes red.
I tried to put it on option 1 (to see if it was not put in to option 0 what disables the IR receiver)
I have only a Beolink 7000 as a remote but i tried to set it to option 1 with a beo 4 that i don't have at hand right now.
I measured on the IR receiver print and it shows signals on the scope when I press a button on the remote so i guess that is good.
I checked also some voltages on the power print inside the unit and they come on for a few seconds and go down when the standby goes from green to red.
I have the service manual but there are no schematics in there.
I have red somewhere that the early models had some high failure rate on the main processor boards that prevented the unit from starting Maybe mine is an early model (type 9201 sw 2.1)
I bought it from a B&O dealer for 25 euros so if I cannot repair it there is no problem but it would be fun if I could succeed.
Hints anybody?
Regards
Ron.
