Beovision 5 Using the y pb pr inputs
Another question...
So I want to hook up my tv receiver to the tv in the best way possible.  The receiver has the y pb pr  outputs and the Beovision has the same inputs.  I've never used these outputs before.  I see on the back of the tv there is also an input with Right and Left for the sound, but they are covered.  There is also two inputs labled H and V.  What are these for?
So I'm guessing I can use the y pb pr for the picture, but have no way to receive the sound this way?
That would leave me with RCA (composite) video inputs thru VTape or one of the other inputs I guess.
Sound can be achieved by using digital input, probably digital coax for surround sound or with a scart to rca converter using the scart input.
Not owning a BV 5, basically setup an input like AV2 with AV2 Scart adapter using rca inputs and choose HD Component YPbPr Input for HD picture (limited to 720p, probably 60 Hz - be sure to set-up input device correcty).
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
Sorry, you don‘t seem to use scart in the US of A.
So RCA is already there.
Hope my first post was helpful nonetheless…
Ralf
