Beosystem 2500 CD MK1 replacement
Hello,
I am a french owner of Beosystem 2500 (1991/1992). The Cd module MK1 does not work any more. I am looking for a CD part replacement.
Thank you for your best advice.
Best regards.
d.dusangatorange.fr
You can use Philips CDM 4 with some modifications.
Thank you for your help.
What do you mean by "some modifications"? Do you think that a specialist can do the replacement with a Philips CDM 4 ?
If you have more details about this possibility, please send me details as docs, links...
With these details i will contact a french workshop.
Regards.
i do it my selfe...no links or docs..
B&O wokrshop will not do it for you...i think.. :(
There is several item called "Philips CDM 4".
Can you tell me the item ref you used to do the replacement on your B&O system?
Thank you.
Need to know - What´s the different between CDM 4/38 and CDM 4/19??
find online old still operating Philips CD player  with CDM 4/19 ...and just replace the laser head from Philips cd to your CDM 4/38..that is it :)
End of story :)
