Dear All,
yes I have gone through a lot of posts and this problem is not new. My Beosound 9000 Mk2 is behaving strangly. Check Out the Videos:
I have cleaned the Prisemens. One was broke and has been glued back (looks totaly fine and clean). Can the prisem for the hand protection System really cause the issue you can see in the Video?
The Sled has fallen slowly to position 6 and now is stuck there. You can hear a small sound that sounds like an attemp to move it to position 1 but nothing happens.
I am thankfull for your thoughts, suggestions and comments.
I was also trying to get it into Test Mode with BEO 4 - it reacts to the remote but I really cannot get it into test mode. Any ideas?
Thanks a lot!
Michael
