Thanks to manfy and beobuddy for the hints - actually the device works again but i do not know why...
There was no ripple on the voltages so power supply seems to be ok. All Voltages are a little bit to high (Main Voltage 32,7 should be between 25-30V, 5V, Motor, Lid and Display at 5,2V should be 5.0)
I succeded in turning on testmode with Beo 4.
Test mode 27 showed Errors ML ERR 32, IIC ERR 104, CD ERR7, SLC ERR 42, APS ERR5 and PWR ERR 20.
After some fiddling i succeded in playing a CD with TM 67 !
Test 71 failed and refused to move the sledge - perhaps because of the missing lid?
After installing the glass lid there was still ERR 42 which seems to have something to do with finger protection system.
Test 71 started, opened the lid and closed it back again but did not move the sledge as supposed.
Suddenly, i dont know why - test 71 succeeded an actually the unit works again.
Only when the sledge ist moving it scratches slightly over the CDs (I adjusted the CD mechanism for flat level surface). After CLEAR ERRS in TM 27 they did not show up again.
Since i want to use the Beosound in a vertical position on the stand - should i adjust the clamper arm in horizontal position or better in the vertical operating position?
Thanks a lot for all your hints!
