Beosound 9000 mk1 cd error 3
Hi  Zoran
I received today CDM 12,4 ereplacement from eBay and it's worked perfect on bs 9000 mk2 type 2563.
Here is a link where you can buy
http://m.ebay.com/itm/Philips-optical-pickup-assembly-CDM12-4-Pro-players-Rowe-Rockola-jukeboxes-/112203280055?txnId=1608902669001
Hi  Zoran
Yes ..i know it's working fine with Ebay laser head.
I saved you 250 usd ...:)..hi hi
That's why i tell you these...I do not give information that are not true :)
Have nice day :)
I to have infrequent trouble with my Beosound 9000 to it just stops reading for a second then plays fine for quite q while then will do the same thing again i have cleaned the pieces that get dusty on the outside edges and that has yet solve the problem i think its a MK2  type 2561 do you know if  this Philips-optical-pickup-assembly would work for mine? and if so how involved /hard was it to replace ? Thanks Roger
