Hi guys
My latest plea of help concerns a BS9000 Type2561 i have just been given this as a spares if you can repair happy days. The unit is in pieces at the moment with no visual indication of life, no red STBY zilch. To get deeper into the issue I examined the power input from mains to unit and found the mains relay PCB 5 with no diode D3 to the relay and a burnt flex from PCB5 to 34P16. Buying a new PCB 5 and lead £42!!!!! reconnecting it up to the unit I attempted to power up and it blows fuse F1 on PCB 5 other fuses on PCB 34 are ok. No 5v at PCB 34P16 pins 1-2. At PCB34 P1 pins 1-2 I have 10.2vAC nothing at TR21 I have the schematics but could do with any pointers , I also replaced the bridge rectifier GBU8D same as removed. Any help please
