Beosound 9000 an beovision avant 55
Hallo
hat jemand schon einmal die Beosound 9000 an den "neuen " Avant 55 angeschlossen?
Und wenn ja was wird alles benötigt?
Gruß Uli
Thank you
Thank you
Thank you
HI
i have same question.
Would like to connect BV55 to BS9000.
And would like to connect BL 3 an subwoofer directly to BS9000 so that tv no need to be ON when i jusf listen to FM radio or cd.
And if i wish to listen TV than just click AUX on my BS9000.
So...what is best option to conect both?
Where to take line out from TV?
Hi marexy,
Thanks for your enquiry.  If you wish to be able to play the 9000 with the TV turned off, then you will need to buy an NL/ML Converter from your local B&O store to connect between the 9000 and the TV.
However, if you are happy to turn on the TV when you listen to the 9000, then you can save €600 and use a simple cable from the 9000 to the TV instead (as mentioned in my post above), with the speakers connected to the TV.
Kind regards, Steve.
Hi Steve
Thanks for answer.
So...it is not possible to Connect BL3 to BS9000 and listen all day FM radio and CD with TV off...and on the evening if i wish to listen movie from TV...i just switch ON the TV and BS900 on AUX?
I there no sound line out from BV55 Avant?
And i will connect Google Chromecast Ultra 4K tk BV55 via HDMI.
Maybe it is possible to take OUT signal from one of RJ45 powerlik socket on TV as  Stereo L+R signal to BS 9000.
Hi marexy,
This is not a good plan, as you will lose all the surround sound capabilities of the TV.  Better to connect the speakers to the TV for surround sound.  If you really don't want the TV on when playing music, the NL/ML Converter is the best option.
hi Steve
ok..how to connect  BV 55 with NL-ML converter  and BS9000?
where to connect speakers  (  maybe PL 4 and PL5 on TV ?
where to connect non B&O subwoofer ?
thanks
Please use a Masterlink cable from the 9000 to the converter, then an RJ45 Network Link cable to the TV.  The speakers and non-B&O subwoofer will connect to the TV.  Please feel free to get in touch via my sponsor link below if you need any help finding the right cables.
