Beosound 5 wall bracket
Does anyone know if i can buy the angled wall bracket for my Beosound5, at the moment it sits flat against the wall. i see now there is some with the angled bracket now. Thanks
When you buy the BS5, the wall bracket with angle is issued with it as one of the options for about 795 Dkr. (about 100+€). The item is listed as number 2193 on the price list with the BS5.
Does the wall bracket with part number 2193 fit both systems, Beosound 5 and Beosound Encore?
How can I mount the Beosound 5 flat to the wall? With the original ring that was delivered inside the Beosound 5 packaging?
I think so. I have a Beosound 5 that was on the table stand. A year or two ago I switched it to the wall. If my memory is correct, the ring that went between the table stand and the Besound 5 was used to mount it to the wall.
I don't know however if it is the same for the Encore.
I finally decided to mount a standard Beosound 5 to the wall. Currently it sits on its table stand. I have bought a wall bracket (the angled thing) consisting of two parts but no screws. :-(
- Which screws do I need for it? 6 pieces.
- Is there a PDF / user manual for the bracket?
I've bought a BS5+BM5 but it didn't arrive yet. It should be with a wall mount, I will give it a look as soon as it arrives.
I'm waiting for it for 2 weeks nows🙁
Keep my fingers crossed for you that it will arrive, soon! Would be very kind from you.
Thanks for the crossed fingers I will need it !
DHL status = delivered to destinstion today, but there's nothing. [:\'(][:\'(][:\'(]
when checking the delivery details I have to enter the zip-code, while doing this they answer, does not correspond to the destination zip-code 😡😡😡😡😡
I'll keep you informed!
Try to calm down, I know how you feel...
Is the tracking number correct? And don't trust the DHL status system! :-)
I got parcels where the status still told me, that the parcel was posted by the sender at its local store even when I signed when the parcel arrived at home.
