Hi there,
I am new to this site so please bear with me if I am not following protocol. I have searched the forum for "Beosound 5 flashing red light" but only found posts on problems with products other than Besound 5.
Here is the issue:
My Besound 5 and Beomaster 5 are the slaves and my Beovision 7 Mk3 is the master. TV and radio worked fine until yesterday evening. When I tried to turn on Radio this morning via the remote in a link room nothing happened. I then went to the room in which the TV and the Besound 5 are located and tried to turn on the system again. Nothing happened. Beosound 5 is neither responding to the remote nor to its wheels. Strangely, even the TV does not work. I noticed a flashing red light on the Beosound 5.
Did a soft restart by pressing the power button on the Beomaster 5 for about 3 seconds. Did not help. Disconnected the TV and the Beomaster 5 from the mains. Waited 10 seconds. Plugged the TV in first, then the Beomaster 5. TV is now working again. Besound 5 remains dead but the red light is not flashing anymore.
What else could I do (please bear in mind, I am not a tech guy)? What is the likely cause? What is a likely cost to fix the Problem?
Thanks for your help.
Pismo
