beosound 5 encore set to option 0
good evening,
by accident I set my beosound 5 encore to option  0 ( sending the following sequence with my beo4 : option, A opt, 0 , go) . Now it is not responding to remote commands anymore
How can I set it back to respond to remote control commands ?
Do the same - replacing the '0' with a '5'.
Option 5 is the default for the Encore.
worked great...everything is back to normal ...thank you
now I have to find a ( smart) way to connect the encore to the speakers of my beovisionor my brocanter 2 : i got the suggestion to use a power link to RCA cable and use the AUX entry  ...I was trying to fond a more "elegant " way to do this and have tried some old beolink converter ( thats when I switched it to option 0)....but could not get this to work
