Beosound 3000 CD not working.
Hi everybody,
This unit is equipped with CDPRO2 mech. when I insert CD unit closes the clamp CD doesn't start to spin after couple of seconds display says load CD. So I think its some kind of focus problem. I have tested both motors they are working ok and cleaned the lens. Trough camera lens I can see visible laser so its not completely dead.  Yesterday I changed all the SMD caps but this didn't fix the problem. If I remember right I have read somewhere that these mechs can suffer some diode problem.
If someone has any ideas I would appreciate them.
Best Regards,
Pete
Unfortunately I discovered the same problem with my Beosound 3000 CD Player.
Are there any hints / recommendation how to repair it?
Great, thank you very much.
Next week-end I will open my Beosound 3000 to remove the laser unit.
Did changing the laser fix your problem?
Replacing the laser will always solve the problem for some time. 99% will work again... for some days, months, maybe a year.
Of course also laser die...
But when in the Environment of the laser is a problem with power supplies or a defect in the regulation Loop of the laser power, then it will be killed again after some time.
First check all caps, then replace the laser. There is a reason that causes the problem, otherwise you just cure the symptom... and just for some time.
