Hi everybody,
This unit is equipped with CDPRO2 mech. when I insert CD unit closes the clamp CD doesn't start to spin after couple of seconds display says load CD. So I think its some kind of focus problem. I have tested both motors they are working ok and cleaned the lens. Trough camera lens I can see visible laser so its not completely dead. Yesterday I changed all the SMD caps but this didn't fix the problem. If I remember right I have read somewhere that these mechs can suffer some diode problem.
If someone has any ideas I would appreciate them.
Best Regards,
Pete
