Beosound 3000, can't set it to Option 2 - and a few other things
Carolpa wrote:
[Did you set the ZONE to ALL (if applicable depending on Beo4)?
● + LIST -> ZONE
It doesn't seem like ZONE is an option in my Beo4...
benkap wrote:
When I press PHONO on Beo4 BS3000 turns on N.RADIO but the speakers stay off. I can choose A.AUX to play records and start from BG4500 manually. But I would really like to be able to use the remote.
Your BS3000 has software installed to work simultanious with a Beomedia, Beomaster 5, or Beomaster/Besound 5.
This sw tells the BS3000 to open a channel to the Beomedia, Beomaster 5, or Beomaster/Besound 5 when given the command A.Tape2 (=N.MUSIC) or Phono (=N.RADIO). So you have to use with the A.Aux command instead to listen to an Aux connected device.
Makes sense - thanks for the info :)
