I recently acquired a Beosound 3000 and want to set it in Option 2.
However, it seems like the BS3000 or possibly my Beo4 is not responding to the command.
On Beo4 I press ● + LIST -> OPTION -> GO -> A.OPT.
As I understand it A.OPT. should then start blinking and I could then press 2 to choose Option 2.
A.OPT. never starts blinking, though.
I have a BG4500 connected and another problem is the BS3000 doesn't recognize phono input, thus does not turn on when I start the record player.
When I press PHONO on Beo4 BS3000 turns on N.RADIO but the speakers stay off. I can choose A.AUX to play records and start from BG4500 manually. But I would really like to be able to use the remote.
Everything worked fine with a BS2500 that was set up earlier.
Any help is much appreciated.
