Hi all, hope you can offer a little guidance to a novice.
i have A new Eclipse Gen2 with Beoremote One BT, latest model without the Netflix buttons. It has replaced an Avant 55 with the first Beoremote One.
i had two Bosscom lamp switches that I controlled via the light option on my original system.
Understanding that the latest remote is both Bluetooth and IR, any suggestions to have a simple use of the remote to turn lights on and off? I do not use scenes or dimming.
installer has configured a BEO4 option in the menu, but it results in at least 6 presses of buttons to navigate to activate light and then same to go back and control the source. All very complex for what is/was straight forward.
Question 1 - is there a simple way to control the IR lights in the new remote ?
Question 2 - can anybody suggest a Bluetooth lamp switch that works with Beoremote one bt?
thanks, appreciate any feedback.
