BeoRemote One BT functions, tips, tricks?
sq2002 wrote:
If someone can show me how to configure the light function into a MyButton I would be very grateful 🙂
You have to switch now from bluetooth to IR, lot's of steps to control the light. After that, you have to go back again all the steps to switch to bluetooth (TV function) again. Not easy, and very clumpsy..
I´m quite sure the only thing you can do is to associate the LIGHT command to a MyButton. Nothing more. That is the way I have arranged it. So rather than pressing LIST and go down the list to LIGHT I can press a MyButton.
Ideally I would like to configure certain light scenes to a MyButton but that is not possible. One would need a BLGW for that.
Millemissen wrote:
PhilLondon wrote:
One thing that doesn't work for me is addressing individual lamps.
With the Beo4 you'd press LIST until LAMP appears, and then press 1 to address the first lamp.
Here you can access the LAMP function from the list but it sends the LIGHT code rather than the LAMP code!!
They told me it was a known bug in the firmware. I got it flashed with a new one and it still doesn't work :-(
Personally I could live without that.
As long as I would be able to adress my light scenarios (I use mostly 4-5 as a combination of 4 individual lamps) and dimm/increase these with ease, I'd be fine.
P.S. But if there is a bug there, they ought to get it fixed.
@MM
How do you access the light scenarios using the BROne?
/C
LIGHT + Digit, if you've got LC2s... There are some scenes you can use as well like Leaving, etc... if you've got a BLGW.
Mybutton and Light : standard the remote starts in bluetooth mode.
can you please show me step-by-step how you programm the light on Mybutton, because as far as I see it you can store it because you need to switch from BT to IR. Mybutton can only store the last 3 steps ??
mybutton + number would be good enough,
but after that you also would need a mybutton to get back to BT
Sorry, I have only the regular BRone
Anyone who in the meantime has a functional mybutton mapping ?
I use lights and home automation quite a lot for my buttons.
Anyone successful in mapping one of the my-buttons on the BR/One 1605 (use to control a Horizon) as Light (to control LC1/LC2) - when in Beovision Horizon mode?
Has there been any update to software that enables an IR-command to be mapped to a MyButton in BT mode?
Either I´m missing something completely simple, or the ones above that mention only 2 button presses to controll their LC2s use the BR/One in IR mode with their TV or music system.
//Goran
Any tips on using the BT Remote to control Philips Hue lights (without having a beolink gateway)?
