If someone can show me how to configure the light function into a MyButton I would be very grateful 🙂
You have to switch now from bluetooth to IR, lot's of steps to control the light. After that, you have to go back again all the steps to switch to bluetooth (TV function) again. Not easy, and very clumpsy..
I´m quite sure the only thing you can do is to associate the LIGHT command to a MyButton. Nothing more. That is the way I have arranged it. So rather than pressing LIST and go down the list to LIGHT I can press a MyButton.
Ideally I would like to configure certain light scenes to a MyButton but that is not possible. One would need a BLGW for that.
